Hello,
When on a call (Sent or Receiving) my microphone doesn't work, the other person cannot hear me.
However if I go to speaker phone they hear me fine.
The microphone works fine in diagnostics.
I haven't downloaded any apps recently.
Is there an easy fix to this?
Thanks,
Solved! Go to Solution.
Uncheck Microphone noise suppression. This may help. It have helped me.
Hi @Sonymanpro,
Can you also please go to Google Settings > Search & Now > Voice > "OK Google" detection and turn it off, then test your phone calls again?
My phone have the same problem.
Now it evolves...I cannot even make a call, and have problems with network carrier.
They send me another SIM and still the same. It works in other phones...
Contact the french support for an exchange.
Really dessapointed with this phone and his laughtable 8GB memory...
Having the same issue as well. I can hear the other party on the phone call but they cannot help me. I ran diagnostics on the phone but could only hear static, but would make a noise if I touched the microphone. I launched the phone in safe mode but no change was made and I then performed a repair update through the companion app but the issue has still not been resolved? Are there any other solutions that could be taken here?
Same problem is safe mode.
Google Settings > Search & Now > Voice > "OK Google" did not work.
Uncheck Microphone noise suppression( In Call Settings) :smileyplus:
This seemed to have fixed the problem.
I was having the same problem and I sent to fix it and one month later started the same problem.
What is going on with this model?
I`m really disapointed with this mobile and I`m sending again to fix it.
Having upgraded my Xperia M4 Aqua (android version 6.0.1) to 26.3.A.0.140 I had the same issue in not being heard on calls made in the car, having used bluetooth to connect to Sync.
Interestingly if I started a call outside the car and then went inside and connected to Sync, my voice could be heard as the call sound transferred from my handset to the car stereo.
I'm very happy to say the suggested setting update worked and I can now make calls from the car.
Microphone noise suppression (Settings -> Call Settings) 'Yes' to 'No'
