- Als nieuw markeren
- Bladwijzer
- Abonneren
- Dempen
- Abonneren op RSS-feed
- Markeren
- Afdrukken
- Ongepaste inhoud melden
I put my SD card in to a tablet to copy mp3 files, then I put it back to my phone(xperia M) it works for a while with no sign of problem. The phone was turned off because it was already low in battery and when I turned it on I can no longer locate my files and when I checked my SD card in file manager all I see was a weird file names that cannot be opened. Is my SD card infected by a virus? Or there is something wrong with my phone or the SD card itself? Help.
Opgelost! Ga naar oplossing.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
I'll try to transfer again some songs and we'll see if this happens again after I charged it when it goes to low battery mode.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Sure,take your time.We need to fix this:smileymrgreen:
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
We'll do. Thanks for your time alexdon :smileysmileywink:
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Always here to help.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Hi I just copied the files again from my tab to my phone and recharged it, so far everything's doing well, files did not disappear unlike before. I think you're right, it has something to do with my SCARD. I actually reformat it before i copied the files from m y tab
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Great,just do not copy large amount of files at one time.Always unmount the card before removing it.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
ok! Thanks again for assisting me on this. I really appreciate it:smileysmileythumbsup:
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
You are welcome,my friend.Come by the forum sometimes.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Sure! i'm just new here so i think it's a good thing to learn more.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
Of course,I also started with a question(if I remember correctly).After that,it was just pure interest.
