No sound from speaker
mnishant07
I bought my mobile a month ago. Since yesterday No sound can be heard frim tis device. No ringtones, no touch tones. Everything works with earphones but without it one would feel as if he is deaf. Tried even safe mode bt same problem exist. Whatto do now?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Samuel1
Zawodowiec
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
11 ODPOW. 11
profile.country.RO.title
_alexdon_
Try settings-apps-all-sound enhancements,force stop and clear data.Restart.
alexdon
mnishant07
Its not working...tried twice
_alexdon_
This is strange.Try to unplug the headset while listening to music or while in a call.
alexdon
mnishant07
Yet Not working... Now!
Samuel1
Zawodowiec
How to backup?
MiK246011
I think you just have some dust in the headphone jack, you should clean it carefully. But before you do that, check "Sony smart connect" app (preloaded) andif it says you've got headphones in, when you don't, clean the headphones jack... Carefully
bruinenat
Hi There
same issue here, no sound from speaker.
Is your problem solved yet?
thank you
Bruinenat
Corekoshe
I have the same problem. Cannot hear anything but calls and an app but youtube has no sound. No ringtone, no alarm, no voice notes from WhatsApp. It's been a month as well... I haven't put it in water or anything. It just suddenly stopped working... I might just take it back and get my money back. Repair my old iPhone and get on with it. And I though moving away from Apple was going to be better... Seems not
Abelturner
I can only turn my m2 aqua on with the charger it will not turn of and there is no volume what do I do?
