You will have to root your phone > partition your SD card and then use an apps2sd card
This is not acceptable for a manufacturer like Sony, because it is clear that 2 GB for applications, the memory is small. Or Sony engineers do not use these phones and not install aplications for them.
Actually that is google to blame not sony.
