Not able to see the File Commander menu on my Sony Experia M
Ramanant
Probably my daughter deleted the menu. I am not sure if she uninstalled it by any chance.
How can i get back the file commander meny on my Experia? I do not want to install other file commanders from Playstore which are not original from Sony.
Thanks
Ramanant
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.RO.title
_alexdon_
Use other file explorer,see if it suits you.
alexdon
10 ODPOW. 10
_alexdon_
File Commander cannot be uninstalled,it can just be disabled.Go to settings-apps-all-look for it and enable.
alexdon
Ramanant
I am not able to see File Commander if I Go to settings-apps-all. :smileyrolleyes:It is not listed there.
_alexdon_
But are you sure that your M had it on 4.3?I know that 4.4.2 has the commander,but as far as I know,4.3 does not have it.
alexdon
rmahmud28
You can get File Commander HERE
Also,
1. Xperia M came with File Commander since 4.1 and CAN be uninstalled
2. It's not made by Sony, it's made by Mobile Systems, Sony just preinstalled it.
Ramanant
Yes, I am sure that my Experia M had it on 4.1.2.
Ramanant
Thanks, but the icon shown is different on this link than one i had originally. It was a blue folder icon. This one looks different as it has a yellow icon with Fk written on it. Slightly_frowning_Face not sure if it is safe to install this one.
_alexdon_
alexdon
_alexdon_
One more thing.After a new firmware update,you should get a file commander back.Wait some more.
alexdon
rmahmud28
The File Commander was updated and so was the icon. Same app, different icon due to updates from the app developer.
