OTG cable
the_breed
OTG cable
Hey guys I am using Micromax's OTG cable with my Xperia M, is there going to be any problem in the future?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Zenvenky
@ the_breed, thanks for your post. This confirms that I can use OTG with my XMD and I'm sure there won't be any issues using OTG.
7 ODPOW. 7
Uliwooly
Problems such as?
Basant
does micromax have an OTG cable at all???? i guess you r referring to the charger/usb cable. Should do no harm at all i guess.
3t
If it is high voltage consuming then it will charge your phone fast and you dnt have to worry it will not harm i guess.
the_breed
@uliwooly problems like any clash with the software??
@basant actually i got it from micromax's funbook.
Zenvenky
the_breed
@zenvenky, (sigh of relief) thanks mate for your reply.
Basant
@the breed..the cable supplied with the M is used for both charging and usb connectivity to PC. Some cables available from other sources sometimes are similar and sometimes support only one of the two utilities. As far as the charger unit goes standard across manufacturers is normally 5V to 5.2 volt output which should be fine with the M. The mAh output varies from 500mAh to 1000 mAh. The higher this fugre the faster your phone battery will be charged. The Sony M charger supplied alongwith the phone is 850mAh and takes about 2 1/2 hours for a full charge from zero. Over 1000mAh output chargers, I would be a little apprehensive of using.
OTG cables all do not work with the M just as all headsets dont. Best to try it out and if it works then there should be no issue for further worry.
