Pokerstars on Xperia M
Alex75
Hi,
can someone who owns the phone please test if the pokerstars mobile application works ?
It requires 480x800 resolution and I'm not sure if the Xperia M will work with it because of the software button bar.
Thanks
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Basant
DOWNLOADED , INSTALLED , SET UP FIRST TIME, AND PLAYED. WORKS PERFECTLY MATE...GO AHEAD N GET URSELF THE XPERIA M Slightly_smiling_Face
6 ODPOW. 6
Uliwooly
It doesn't work for you? Keep in mind that compatibility issues have to be addressed by the app/game developer
Alex75
Thank you for your answer uliwooly. I don't own an Xperia M I currently have a Go and I would like to get the M but I would like to know if it can run the Pokerstars mobile application, If an owner can test it, it would be great.
Basant
The App shows as compatible with the Xperia M on playstore. Display resolution i dont think should be a reason for the game not functioning on any cellphone.
Basant
downloading now...
Basant
Alex75
Thanks a lot for taking the time to test it Basant. I'm gonna get it tonight.
