My fingers are **bleep** worn out after trying to remove the SD card time after time; I'm really getting pissed off at such a poor design, what, am I supposed to pressure the thing so it comes out? IT DOESNT. I've tried everything already and I will break the phone out of rage How do I remove the card without losing a finger or two? Why not add a simple switch do take it out. Lazy design.
When the card is put into the slot, it drops down over a small 'lip'. To remove the card, you need to lift the back end slightly as you pull it out - I use a pair of tweezers. Stating the obvious - you need to be careful to lift only the minimum needed to release the card as it is possible to snap it in two.
it shouldn't be hard, perhaps you put it backwards, and that's why you can't remove it
http://userguide.sonymobile.com/referrer.php?region=global-en&product=xperia-m#!Assembly.html
Well I overreacted because I got mad at it being so complicated for no reason, thanks for the replies.
