Xperia M Dual does not have Developer Tools Option
Kaze11
I recently bought Xperia M Dual, and it does not have Developer Tools option. Even a cheap smartphone have that option.
Is it just my mobile problem or there is no Developer Tools option in M Dual.? How to do USB debugging?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Uliwooly
it does, google has hidden this option
Settings > about phone > scroll to the bottom > type few times on build number
14 ODPOW. 14
Uliwooly
kartikmandavia
setting/developer option /debugging
rmahmud28
@android 4.2+ phones, what @uliwooly said is correct.
ajit1992
I'm new to android phones and even I wanted to find the Developer tool option for USB debugging.
As per the suggestion given by uliwooly after 2-3 clicks it pops a message "you are 4 steps away from being a developer".
Is it safe to unhide the developer tool option?
or is there any disadvantages?
Please reply ASAP.
profile.country.RO.title
_alexdon_
There is no problem showing the developer options,in older software,it was visible all the time.The problem will be if you change parameters which you have no knowledge about.
alexdon
ajit1992
Will it affect the warranty terms and conditions?
If yes, in what way?
_alexdon_
No,it will not affect your warranty.
alexdon
ajit1992
Thank you alexdon for helping me.
_alexdon_
You are welcome.
alexdon
