3 quick questions...
SOLVED
Not applicable
Hey three quick questions about the phone...
1. Is there any way you can delete several texts in a conversation, rather than deleting the entire conversation or a number of individual texts?
2. How do you turn only 3G off? or is that simply managed by data traffic?
3. When editing and registering the email feature and selecting a connection type, it gives you POP3 and a IMAP4 option. Which should i choose and what do i need to enter below those to allow you to register?
Cheers!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
open your messaging app, press menu -> settings uncheck notification tone, notification vibration and notifications
8 REPLIES 8
Uliwooly
1) just long press on each text (within a conversation) and then tap on delete
Not applicable
yea but is there any way to delete more than one at a time?
Uliwooly
Uliwooly
you can go to
settings -> wireless & networks -> networks and uncheck data traffic or download this app
https://market.android.com/details?id=com.curvefish.widgets.network2g3gonoff&feature=search_result
Not applicable
brilliant apps for turning off 3G and handcents good too! Thanks 😃 by the way, any idea how to turn off the notification from the original messaging? So that i just get handcent notifications?
Uliwooly
Not applicable
cheers, much appreciated 😃
Uliwooly
anytime
