Android update
SOLVED
peel_balaji
Visitor
Android update
Hi,
I m using LWW. I purchased 2 months ago, but didn't get any updates for Android 4. When i checked in the serial number list, my Serial number starts with 1262 was not there. Is there any guess or expected date of the release of new serial numbers for android 2.3 to 4??? Please inform as soon s possible. Also want to know whether i will get any notification on my mobile regarding Android update.
Regards,
Balaji V
1 ACCEPTED SOLUTION
Accepted Solutions
peel_balaji
Visitor
7 REPLIES 7
Uliwooly
is your phone locked to a network/network branded? if it is contact them as some networks are not going to release the update
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
Uliwooly
Here is an alternative
How to manually update 2011 Xperias to android 4.0.4
http://talk.sonymobile.com/thread/38251
peel_balaji
Visitor
Hi,
wats that locked to a network/network branded. I didnt understand. I am using Vodafone IN. Please tell me more about this.
peel_balaji
Visitor
Once if we root the phone, is it possible we can unroot the phone again to older version?
Uliwooly
yes you can unroot either by using the same method or repairing your phone with SUS or PCC or flashing your phone with flashtool.
peel_balaji
Visitor
peel_balaji
Visitor
Hi, i would like to know wats that VFD2 in my mobile. i don't know wats that? when i checked it with my friends mobile, it was not there. Hope is this the reason that i didn't get android update.. Please reply as soon as possible...
