auto rotation issue - xperia v
Tougheart
This is a new xperia v I got two days ago, first day it was perfectly fine, put it on charger, went to sleep, and in the morning I found out that it stays on landscape the whole time when I have auto rotation on, no matter what position it is on, it won't go portrait.
Can someone help me with this issue please?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
That sounds quite strange. Have you tried to remove the battery for a while?
7 ODPOW. 7
Uliwooly
the only way it will rotate is if its connected to a Dock, otherwise only apps will rotate (whenever you open them)
Tougheart
Apps rotate according to the phone's position, and that's what was happening the first day, then almost all the apps (Chrome - Google Play - Facebook) for example are always on portrait no matter what position the phone is on
Tougheart
I didn't try that, for how long do you think I should do it?
Uliwooly
If it all fail you can repair your phone with SUS or PCC
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Tougheart
Thanks Alexander, that worked.
But what would be the reason behind that?
It's hard to say what may have caused the problem. It might been some 3rd party app acting up or something else. If it works fine now, the behavior should not get back.
Please keep us updated if this happens again.
