background data??
Nie dotyczy
background data??
menu->support->tools->battery saver-> background data
im using gingerbrid, and i found this recently, what does it do? and what does it mean? does it affect the performance??
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.PH.title
MarlonUk1
it allows apps to use data even in the background. well it does consume battery most especially if there are lots of apps sending data thru your network, you can see if they send background data before you install them (permissions).
2 ODPOW. 2
MarlonUk1
Nie dotyczy
thx, that help me..
