hello. i've just updated to the latest software but did a backup of all contacts and msgs etc using backup and restore. the new software doesn't have that app so i can restore my contacts and msgs etc to the phone. anybody got a clue how to do it?
thanks
once you restore everything you should do the following for future reference (just in case)
Don't forget to check the other Apps to backup your phone
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Contacts
SMS/MMS
or your SMS use
Call Logs
if the link above doesn't work to download the app you can get it here
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.mediafire.com/?1n07llajeaoo03y
there seems to be more than one version of the backup & restore app
thanks a lot for the help. got my phone restored
I'm glad I could help
don't forget to use the other apps/methods to backup/sync your phone
