Is this results of of my sony xperia p normal??
How do youu rate the battery performance of it -normal or below normal?
and also how doo you rate my usage -heavy or medium usage?
Solved! Go to Solution.
Your battery autonomy is normal,you had wifi on all the time + other apps and games.I think you are a medium user:smileysilly:
Well his battery autonomy is way better than normal, I would call it excellent. I have never reached 5,5 hours with WiFi on. I can see you have extended battery mode switched on, but still. There's nothing to worry for you.
I would personally remove Avast though, anti-virus software isn't needed really.
Same goes for the battery app you have installed, which one is it? I think it might do more harm than good, which would result in a better battery backup if you remove it.
It isn't battery app its notification toggle app fr quicker access..!
Ok then,it is a very good battery performance.The antivirus is not for need in Android.You could do well without it,as majesty said.
Ok then i'll uninstall antivirus. Thnks fr ur rply.
