dear sir,
i have andoid version 4.0.4 on my sony xperia tipo st2i but am still unable to install bbm application from the android market.the msg runs "this item isnt compatible with your device" and the minimum requirement for the application is android 4 and above.Hoping for a reply at the earliest.
thankyou
Try using this tricks (using PC):
1. Open: http://apps.evozi.com/apk-downloader/
2. Copy - Paste this Officiall BBM link: https://play.google.com/store/apps/details?id=com.bbm to its Package name or Google Play URL box
3. Press Generate Download Link, wait while its generating download link
4. When Ready, Download its apk to your PC
5. Transfer bbm.apk to your TIPO
tested on my TIPO
That's up to the app developer to fix, it might be a hardware or software compatibility or it could be a regional/country restriction
me too, I cannot instal BBM for Android on my Xperia Tipo
neither do I, why it is happened? I need explanation ASAP. Thank you
not working for xperia tipo .! even my phone has 4.04 version and it is said 4 and above so please make sure bbm should work in my and others tipo .!
thank you
