Cool,right?
SOLVED
profile.country.RO.title
_alexdon_
Cool,right?
Look at his my friends.Sony Xperia P at it's best.The pictures were taken last night.I noticed that even though the phone is idle,the screen sometimes works..If you look at my pics,you can see i had 12hrs and 23 minutes.This morning,at 10, i had about 13 hrs and 15 mins,even though i didn't use my phone since 3 am this morning when i came home from a wedding.Anyway,the performance is good,considering i used wifi and played games.The real problem of this phone is the calls.Lucky for me that i had only 34 mins of calls,so the battery could do more.If i make calls over 2 hrs,the battery sucks.
alexdon
1 ACCEPTED SOLUTION
Accepted Solutions
_alexdon_
Anyway,don't you think that the call autonomy of XP is bad?2 hrs of calls and the battery goes down with almost 40-50 %.and what do you think about the display?As i said,my screen wasn't on until 10 am this morning,since 3 am last night.but still,i got some display time in addition to what i had before.
alexdon
6 REPLIES 6
Sagar
Visitor
If you keep your Data disabled any XP will give you more than 2 days of battery life. I used to get it when I was not using data. But now my phone gives backup for a day only while the data is on all the time with auto sync enabled... I use Gmail, Gtalk, FB and WhatsApp.........
_alexdon_
I don't think it is true,because if you play games or talk a lot you don't get anything even if data disabled.And if you have battery problems after ICS update,you won't get more than one day.
alexdon
Sagar
Visitor
Correct... If you play games it wont last even for a day.
_alexdon_
alexdon
farhan1
Visitor
i will say u have a superphone Winking_Face
_alexdon_
Thank you my friend.
alexdon
