Hi,
I keep getting a message saying my Experia Ray can not synchronise (exact words are 'Could not synchronise').
When I click the Account Settings then I get
Server Address: https://sync.sonyerricsson.com/snyc/server
Username: 59ram2n2
Passsword: Cant change this.
It is trying to sync my contacts/Calendar and Boookmarks.
Any help greatly appreciated.
Paul
http://talk.sonyericsson.com/thread/27483
It's goodbye to the Sony Ericsson Sync Service.
And hello to the Google Sync Service.
Thanks a million!! I'll now remove the Sony sync!
you should sync w/ google
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
and also might as well backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Our sync service has expired. Your email account that you signed up with should have receieved an email last week.
You will want to use the Google sync services from now on.
Check out this link for all the information: http://www.sonyericsson.com/contactsmigration/?cc=gb&lc=en
