developer option in 4.3 update
sahilsam
how to get developer options in 4,3 update
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
saeedmohd
go to Settings-about phone-tap about 6-7 times on the build number u will get wht u need
8 ODPOW. 8
le_Bob
Settings >about Phone> tap "build number" often until it comes a message that you are a developer now, go back to settings and the developer options will be there
saeedmohd
chinnav
where is the eco mode controller in xperia sp after update of 4.3 jelly bean
profile.country.RO.title
_alexdon_
Settings-apps-all.
alexdon
chinnav
ok thank u for stting developer option..........apart from that  the illumination bar is not blinking.. while the song is playing why???
the problems after upgrading to 4.3 JB.....please reply meeee regarding this issue.........
PRASANNA
Hi Chinnav
The Illumunation bar effect is something which is being bugging all the users after the update , the beat effects works with low volume and glow on high volume.. May be the next firmware update which is on cards might fix the bugs.. if anything other than the illumination bar is bugging you then recommend you to perform reset factory settings
_alexdon_
Download a 3rd party app for the illumination bar.
alexdon
mani92144
after updet my phone bravia engine is not working and my phone very slow,apps automaticly close and not responding and i repair phone.....4.1 best but 4.3 not good for sp...please resolve it
