Hi, was just wondering is there any safe way to disable time scape from the home screen without completely removing it? I want to use a photo wallpaper and the timescape exactly in the middle kind of ruins the fun.
Solved! Go to Solution.
Hi, you can easily remove it, long press Timescape icon, drag it to the bin that appears at the bottom of the screen.
Oh Thank you, can finally use my gf's picture now :smileygrin: How to bring it back again btw?
To bring it back, long press on an empty space (make sure there is enough room), a Home Screen Menu will appear, select Widgets>Timescape Widget.
