Disabling TimeScape.
SOLVED
Not applicable
Hi, was just wondering is there any safe way to disable time scape from the home screen without completely removing it? I want to use a photo wallpaper and the timescape exactly in the middle kind of ruins the fun.
1 ACCEPTED SOLUTION
Accepted Solutions
gwhispererz
Champion
Hi, you can easily remove it, long press Timescape icon, drag it to the bin that appears at the bottom of the screen.
3 REPLIES 3
gwhispererz
Champion
Not applicable
Oh Thank you, can finally use my gf's picture now :smileygrin: How to bring it back again btw?
gwhispererz
Champion
To bring it back, long press on an empty space (make sure there is enough room), a Home Screen Menu will appear, select Widgets>Timescape Widget. Slightly_smiling_Face
