Does arc support video calling bcoz it is not having any front camera???
Nie dotyczy
plz help me out on this....plz
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Dr_Chris
VIP
No, it does not support video calling.
7 ODPOW. 7
Dr_Chris
VIP
Nie dotyczy
if they will install a front facing camera in ARC .....then it will be my next phone.............sony go for it because i m a great fan of xperia family....
Uliwooly
you should check the Neo, it has a frontfacing camera
an2ny79
or wait for PRO.. if Im not mistaken, it has front camera..
I haven't seen Arc, but I anticipate to buy PRO.. if you would compare, there are more features in PRO than Arc..
Uliwooly
the neo has a front facing camera too, so I'm debating between arc or neo if I buy a SE phone
an2ny79
If the only thing neo has surpassed arc is because of this front camera, then I would suggest go for Arc.. You won't use this feature in your daily life 😜
Uliwooly
I havent been able to find an app that will allow to use the rear camera for videocalls, do you know of any apps? besides fring
