- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
It’s been 3 months from when I am using Xperia Mini Pro (SK17I) and I completely agree that I enjoy using it. But from last today I am getting sort of error message whenever I receives any text message. Whenever a new message pops in there comes a Notification which says "Text Message full please delete some messages to read new message", and after that I was really shocked that how can my message memory can be full as I was having around (500 or 600) messages in my box, but even then without wasting any time I just deleted all my messages and that notification / alert message was gone. Then after 2 or 3 hours that message again pops in and it said same thing "Text Message full please delete some messages to read new message", but this time I was having hardly 20 or 30 messages in my box.
Now that’s what brings me to surprise that is my message capacity is so low? Or is there or bug or something? I am really worried about this problem,
Can someone let me know that why I am getting this error? What can be the reason?
Please help me out. Need some expert’s advice in it.
Regards,
Abhi Shreshtha
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Make sure you backup everything
Use one of this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
this seems to be another issue, backup everything and then repair your phone with Update Service or PC Companion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
other things to try, go to
settings -> applications -> manage applications -> all -> messaging app -> clear everything there
turn off your phone -> take the battery out -> press and hold the power button for 5 seconds -> put the battery back on and turn on the phone, see if you get the same error
if you do, you can try a factory reset
settings -> privacy -> factory reset (this will delete everything )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
or
How to install it
You need to
Contacts
SMS/MMS
or your SMS use
Call Logs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks alot for such a quick reply, but can you please explain me more that what all things will be deleted from my phone if i go for factory reset ? and will factory reset will provide me guarantee solution from this problem ? please reply. and thank for your quick response.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
factory reset might or might not fix your problem, as well as repairing it with PC Companion or Update Service. but if you look above, I gave you ways to "backup everything" so even if you delete all your apps and all that, you can still restore them. I would try the other approach first
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sure, i am first going to check out this step :
settings -> applications -> manage applications -> all -> messaging app -> clear everything there.
And if it wont work then ill try useing other hand. and one more thing meanwhile I am updating my Phone what do you think can this solve my problem ?
and I got all your links must say they are rally helpful and easy to note.. Thanks for your help, lets see how it works. Fingers Crossed !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I would back up my phone and then use PC Companion or Update Service to repair it, btw do you have android 2.3.4?
settings -> about phone -> Android version and Build number
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It says I have Android Version : 2.3.3 and Build NUmber : 4.0.A.2.335
but now i am updating it with 4.0.2.A.0.42 SHOULD I GO FOR IT ?
and the link which you just gave i think its for the same right ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
did you backedup everything?
if you don't you will lose EVERYTHING
