Hello there, I was trying to flash my phone(sk17i) with the firmware 4.0.2.A.0.62. My existing firmware was .42. It was going alright. I followed the steps from Sony support forum accordingly. When the flash was completed to 100%, the flashtool wasn't showing any confirmation message. I waited for a long period. Then I unplugged the phone and switched on. Sadly it is not starting up:smileysad:. Just showing Sony Ericsson logo and an icon then going off. I'm trying to reflash it but shows error message. I've also tried SUS.it wants the device fully charged but it's not charging too. I know it's my severe mistake to disconnect the phone. But what should be done to recover my phone's software? Please help me. Your helpful answer is highly appreciated. Thanks in advance.
for your convenience i attached the log bellow:
03/053/2012 22:53:42 - INFO - <- This level is successfully initialized
03/053/2012 22:53:42 - INFO - Flashtool Version 0.8.0.0 built on 2012-05-27 21:57:12
03/053/2012 22:53:42 - INFO - You can drag and drop ftf files here to start flashing them
03/053/2012 22:53:51 - INFO - Device connected with USB debugging off
03/053/2012 22:53:51 - INFO - For 2011 devices line, be sure you are not in MTP mode
03/053/2012 22:53:51 - INFO - Device connected with USB debugging on
03/053/2012 22:53:52 - INFO - Connected device : SK17
03/053/2012 22:53:52 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-04-04 18:40:20 CDT) multi-call binary.
03/053/2012 22:53:52 - INFO - Android version : 2.3.4 / kernel version : 2.6.32.9-perf
03/053/2012 22:53:54 - INFO - Remounting system read-write
03/053/2012 22:53:54 - INFO - Installing toolbox to device...
03/053/2012 22:53:54 - INFO - Pushing C:\Flashtool\custom\root\ftkit.tar to /data/local/tmp
03/053/2012 22:53:55 - INFO - Running installftkit as root thru sysrun
03/053/2012 22:53:55 - INFO - Root Access Allowed
03/056/2012 22:56:02 - INFO - Selected SK17i_4.0.2.A.0.62__1251-0103_.ftf
03/056/2012 22:56:02 - INFO - Preparing files for flashing
03/056/2012 22:56:14 - INFO - Please connect your device into flashmode.
03/056/2012 22:56:25 - INFO - Device disconnected
03/057/2012 22:57:05 - INFO - Opening device for R/W
03/057/2012 22:57:06 - INFO - Start Flashing
03/057/2012 22:57:06 - INFO - Flashing loader
03/057/2012 22:57:06 - INFO - Ending flash session
03/057/2012 22:57:06 - ERROR -
03/057/2012 22:57:06 - ERROR - Error flashing. Aborted
03/057/2012 22:57:06 - ERROR - Drivers need to be installed for connected device.
03/057/2012 22:57:06 - ERROR - You can find them in the drivers folder of Flashtool.
03/057/2012 22:57:07 - INFO - Device connected in flash mode
03/057/2012 22:57:33 - INFO - Device disconnected
03/003/2012 23:03:46 - INFO - Device connected in flash mode
03/004/2012 23:04:26 - INFO - Device disconnected
03/004/2012 23:04:47 - INFO - Device connected with USB debugging off
03/004/2012 23:04:47 - INFO - For 2011 devices line, be sure you are not in MTP mode
03/005/2012 23:05:51 - INFO - Device disconnected
03/008/2012 23:08:57 - INFO - Device connected with USB debugging on
03/008/2012 23:08:57 - INFO - Connected device : SK17
03/008/2012 23:08:58 - INFO - Installed version of busybox : BusyBox v1.18.4 (2011-04-04 18:40:20 CDT) multi-call binary.
03/008/2012 23:08:58 - INFO - Android version : 2.3.4 / kernel version : 2.6.32.9-perf
03/008/2012 23:08:59 - INFO - Root Access Allowed
03/014/2012 23:14:23 - INFO - Selected SK17i_4.0.2.A.0.62__1251-0103_.ftf
03/014/2012 23:14:23 - INFO - Preparing files for flashing
03/014/2012 23:14:43 - INFO - Please connect your device into flashmode.
03/014/2012 23:14:48 - INFO - Device disconnected
03/015/2012 23:15:16 - INFO - Device connected in flash mode
03/015/2012 23:15:16 - INFO - Opening device for R/W
03/015/2012 23:15:17 - INFO - Reading device information
03/015/2012 23:15:17 - INFO - Phone ready for flashmode operations.
03/015/2012 23:15:17 - INFO - Start Flashing
03/015/2012 23:15:17 - INFO - Flashing loader
03/015/2012 23:15:19 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Bootloader status : ROOTABLE
03/015/2012 23:15:19 - INFO - Flashing kernel.sin
03/015/2012 23:15:22 - INFO - Flashing fota1.sin
03/015/2012 23:15:22 - INFO - Flashing fota0.sin
03/015/2012 23:15:23 - INFO - Flashing adsp.sin
03/015/2012 23:15:26 - INFO - Flashing amss_fs.sin
03/015/2012 23:15:26 - INFO - Flashing amss.sin
03/015/2012 23:15:36 - INFO - Flashing apps_log.sin
03/015/2012 23:15:36 - INFO - Flashing system.sin
03/017/2012 23:17:22 - INFO - Ending flash session
Hey, I've repaired the phone finally:smileylaugh:. I used SUS and updated my mini pro to ICS. The change is good. My phone is no more Sony Ericsson, it's just SONY. The touch is working better than before though some areas are still not working. Could repair via PCC bring any positive result to my phone? THANKS.
