Flash tool error....
RoginskisLV
My Phone Sony Xperia XZ F8331... Help me.... My Phone (the software update failed make sure that your phone is connected and try again) HELP MEEE...
29/015/2020 22:15:29 - INFO - <- This level is successfully initialized
29/015/2020 22:15:29 - INFO - JAVA_HOME : c:\flashtool\x10flasher_native\jre
29/015/2020 22:15:30 - INFO - Flashtool 0.9.28.0
29/015/2020 22:15:30 - INFO - Searching for a web proxy
29/015/2020 22:15:30 - INFO - No proxy found, using direct connection
29/015/2020 22:15:30 - INFO - Syncing devices from github
29/015/2020 22:15:31 - INFO - Opening devices repository.
29/015/2020 22:15:31 - INFO - Scanning devices folder for changes.
29/015/2020 22:15:42 - INFO - Changes have been found. Doing a hard reset (removing user modifications).
29/015/2020 22:15:45 - INFO - Quietly closing devices repository.
29/015/2020 22:15:45 - INFO - Devices sync finished.
29/015/2020 22:15:46 - INFO - Loading devices database
29/015/2020 22:15:46 - INFO - Loaded 72 devices
29/015/2020 22:15:46 - INFO - Starting phone detection
29/015/2020 22:15:48 - INFO - Device disconnected
29/016/2020 22:16:18 - INFO - Selected Bundle for Sony Xperia XZ(F8331). FW release : 41.3.A.2.192. Customization : Customized CE1
29/016/2020 22:16:18 - INFO - Preparing files for flashing
29/019/2020 22:19:22 - INFO - Please connect your device into flashmode.
29/019/2020 22:19:37 - INFO - Using Gordon gate drivers version 3.2.0.0
29/019/2020 22:19:37 - INFO - Opening device for R/W
29/019/2020 22:19:38 - INFO - Device ready for R/W.
29/019/2020 22:19:38 - INFO - Reading device information
29/019/2020 22:19:38 - INFO - Phone ready for flashmode operations.
29/019/2020 22:19:38 - INFO - Opening TA partition 2
29/019/2020 22:19:38 - INFO - Current device : F8331 - CB512F1LYB - 1304-9023_R1E - 1302-9157_41.3.A.2.192 - GENERIC_41.3.A.2.192
29/019/2020 22:19:38 - INFO - Closing TA partition
29/019/2020 22:19:38 - INFO - Start Flashing
29/019/2020 22:19:38 - INFO - No loader in the bundle. Searching for one
29/019/2020 22:19:38 - INFO - No matching loader found
29/019/2020 22:19:38 - WARN - No loader found or set manually. Skipping loader
29/019/2020 22:19:38 - INFO - Loader : S1_Root_de8d - Version : 1299-4832_S1_Boot_MSM8996_LA2.0_O_204 / Boot version : 1299-4832_S1_Boot_MSM8996_LA2.0_O_204 / Bootloader status : ROOTABLE
29/019/2020 22:19:38 - INFO - Max packet size set to 4M
29/019/2020 22:19:38 - INFO - USB buffer size set to 512K
29/019/2020 22:19:44 - INFO - Parsing boot delivery
29/019/2020 22:19:44 - INFO - Found a template session. Using it : C:\Users\Sandis Roginskis\.flashTool\firmwares\prepared\41.fsc
29/019/2020 22:19:44 - INFO - Set loader configuration : [00 01 00 00 00 0C]
29/019/2020 22:19:44 - INFO - Opening TA partition 2
29/019/2020 22:19:44 - INFO - Writing TA unit 00002774. Value : 01
29/019/2020 22:19:44 - INFO - Closing TA partition
29/019/2020 22:19:44 - INFO - Processing partition-image.sin
29/019/2020 22:19:44 - INFO - Checking header
29/019/2020 22:19:44 - INFO - Flashing data
29/019/2020 22:19:44 - INFO - Processing cmnlib_S1_Boot_MSM8996_LA2_0_O_204_AID_4_PLATFORM-TONE-COM-LIVE-HWID009470E1-SWID0C-APPID01-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-DE8D-0004-MMC.sin
29/019/2020 22:19:44 - ERROR - Processing of cmnlib_S1_Boot_MSM8996_LA2_0_O_204_AID_4_PLATFORM-TONE-COM-LIVE-HWID009470E1-SWID0C-APPID01-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-DE8D-0004-MMC.sin finished with errors.
29/019/2020 22:19:44 - INFO - Flashing finished.
29/019/2020 22:19:44 - INFO - Please unplug and start your phone
29/019/2020 22:19:44 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
29/019/2020 22:19:47 - INFO - Device disconnected
and problem Xperia Companion UEUpdateFailed ue_2005
Windows 10 pro 64bit....Help me please FIX Slightly_frowning_Face
2 ODPOW. 2
profile.country.PH.title
MarlonUk1
Hello @RoginskisLV
 might i suggest to go on XDA forums for your flashtool and flashing troubleshooting.
https://forum.xda-developers.com/
MickeyPlus
Firmware tft file dont have bootloader. Try with another tft image, try to download fw with xperifirm
