Question - How do I save pictures from text messages on experion 10 phone?
Thanks
Kath
Answer - Open message, long press picture, then tap Save picture. I hope I remember this correctly ;).
There's a better way to do it
Download
"Save MMS" by Andrew Schwimmer.
once its installed, just open it and ALL the pictures or vids or files you have in your txts will be displayed here, just press on them either accept the default title or change the name of the picture/vid/etc and press save. it will be save in your SD card.
Thanks so much, your way works.
Will download this and try it too. 🙂
