ICS ISSUE
SOLVED
ashima
Visitor
ICS ISSUE
HELLO,
my friend and I just purchased sony xperia s handset. She upgraded her phone to ICS while i havent. After the upgrade, she is not able to download from the play store or the browser. She is using 3G. When she tries downloading, it just gets stuck to downloading.
if we follow this
Settings > apps > all > google play store > clear data
will all the apps get deleted too?
and what if nothing happens? should she downgrade it? Slightly_frowning_Face
please help.
i m hesitant to upgrade because of this issue. but i really want to upgrade it without such problems.
please guide.
11 REPLIES 11
ashima
Visitor
thankyou guys for your support!! 😄
i mailed sony support and they adviced me to do a full factory reset. i followed their instructions and voila! its working again! app are getting downloaded! no problem whatsoever! :smileygrin:
xperia s is an amazing phone!! ^_^
rubaiat_imam
Visitor
I am also unable to connect to the Play Store since upgrading to ICS on my Xperia Arc S.
What is the proces for this restoration to factory presets?
