individual ringtones
SOLVED
Not applicable
Is it possible to set individual ringtones for different people in my address list on my W518A? If so, how do I do it?
1 ACCEPTED SOLUTION
Accepted Solutions
Dr_Chris
Champion
If it is, from Main screen go to Contacts--highlight contact--Options--Edit contact--click right twice--Ringtone--select Add--select a ringtone and save
3 REPLIES 3
Dr_Chris
Champion
Not applicable
Thanks a lot Dr. Chris. That worked!
Dr_Chris
Champion
That's great. Wasn't sure if your phone had this feature, so was only going according to the W995.
