Installing application problem
SOLVED
Not applicable
I am having a problem when downloading apps from the android marketplace.
Most times when the app is downloaded and installed it is placed on a new screen even though there is enough room for it on the previous screen.
This has now led to about 7 screens and 3 of which are full.
Is there anyway to get the apps to be placed one after another and not on a new screen?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
tap the center square to reveal your apps, then on the right side you should be able to see a square made out of four squares, tap on it. Now you can arrange the apps in any order that you want.
4 REPLIES 4
Uliwooly
Uliwooly
Xperia arc Home Launcher
bottom right corner
Not applicable
Thanks for the help. It is much more organised now. Annoying how it seperates them though.
