When ever i tried to update shows like this and i installed FW Through Flashtool with official ICS Given from Sony Site...
Please some one help to me and am from india SI 1254-8966
Thanks.
Solved! Go to Solution.
It means you have unlocked your bootloader
If you want to use SUS or PC Companion then relock your bootloader
Just download and flash this file using flashtool
http://www.mediafire.com/file/g1b5j712ajx4yjd/Xperia_Relock_bootloader.ftf
I think you still got your bootloader unlocked, lock it first and perform an update with SUS
Ok will Try it Thank you...
I have another Question....
Once we unlocked bootloader
After that if we reinstalling the FW through Flash tool and triying to update the using PC Campagain mean if its shows same error message?????
ICS given from Sony site ?
There are no links on sony site so what are you referring to ?
Can you link me the rom you used ?
:smileylaugh:,
Okh do one thing.
Follow my first post above and then try to use SUS
Thanks Dude it works fine
How to find that bootloader is locked or unlocked
