my phone got into blind people(voice guidance) mode how to come out of it, i switched off my mobile even though it is in the same mode plz help me out as early as possible.
Hi
Thank you guys I was really tensed with this activation
you guys sloved it
NIKHITA
thanks alot u saved me
go to settings < acessibility<talkback<click on it press off . blind mode will be deactive
SOOOOOO grateful of this info I was about to burst into tears I don't even know how a blind person would benefit from those settings (I work with the blind and partially sighted) thank you for your help 🙂
Thankyou so much!!!!! Relieved to find this information and glad i managed to get rid of that!!
I can't enter the phone unlock code in this mode. I have tried double-tapping each key but they just appear twice. It tells me that the pin is incorrect when I enter what I know is the correct pin. What can I try now?
How do I get the application for blind people off of my Moto X cell phone
