no connexion
Nie dotyczy
no connexion
When i try to open a website i get the message: network not available. Worked previously very well. Is something wrong with the phone?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
sushidushi
Could it be something as simple as the phone not being connected?  Do you have the 3G or wifi symbol at the top of the screen?
5 ODPOW. 5
sushidushi
Nie dotyczy
Thanks! Problem is solved. Indeed the 3g symbol wasn't there. The UMTS-send installation was out of order all day. It had nothing to do with my xperia.
sushidushi
Phew!  Glad it's now sorted out.  Slightly_smiling_Face
Nie dotyczy
nvm
sushidushi
nvm?
