No update available (wt) ?
SOLVED
drake
Visitor
So my phone is on version 4.0.4, and when I connect it to the PC suite it says there is no update, how do I get the update.
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you have to wait until the update its available in your country and/or region or approved by your carrier/network
Don't forget to mark the Correct Answers & Helpful Answers
8 REPLIES 8
Uliwooly
Uliwooly
if you can not wait, here is an alternative
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
drake
Visitor
Oh , OK that will probably never happen, since I just bought it 3 days ago and it doesn't have an update, they probably don't care, I have a question is it dependant on the SIM (if I get a card from say a british mate will it help) or the phone itself?
Uliwooly
its not SIM card dependant, this should explain the update process
http://developer.sonymobile.com/2011/12/07/ice-cream-sandwich-from-source-code-release-to-software-u...
drake
Visitor
Thanks, well then I suppose I'll stay with the 4.0.4 theres no way I will ever get the update.
Uliwooly
there's an alternative (check above)
drake
Visitor
Yeah I read that, but don't want to void the waranty when its only 3 days in (2 year waranty here) will definetly buy my next phone of the internet. Had a samsung before and noticed this, android support here is horendous, when compared to apple. Its like they ring the providers up and say so do you want your clients to have the newest and best, no thanks.
Uliwooly
lol you are funny, this forum is for US, USERS, to help each other, if you want support by Sony then you have to contact SONY directly
http://www.sonymobile.com/global-en/support/contact-us/
