Condividi la tua esperienza!
I've updated my mini pro to ICS using SUS and I don't know if everyone is experiencing this problem but my notification sound will get randomized everytime I turn my phone off and on again or when it runs out of battery. My phone will just pick any notification sound I have, from the stock notification sounds to my mp3/wav notification sound.
I have to re-set all notification sounds for all my IM, emails and phone calls.
uninstall taskiller -> restart your phone and check again
Don't forget to mark the Correct Answers & Helpful Answers
are you using a third party dialer, third party phonebook taskillers antivirus?
nope, nothing, just plainly installed ICS with google+, whatsapp, facebook, google talk, gmail...no third party apps for dialer and phonebook ...I installed advanced task killer and so far didn't use it because I've found nothing to kill...
hm....somehow the problem is gone but it's hard to believe that this app is causing the problem...
oh you'll be surprised how this poor coded apps create all this problems, same with anti-virus
Dear uliwooly = >>> Any idea on how to have seperate volume levels for Ringtone and notifications.
This feature is broken in ICS??
it's not broken, that's how android work
I used to have it working in my GB, You may try installing Volume Control+ widget from here in your GB phone and choose settings -> System Settings and uncheck link notifiacation and Ringtone
I have GB on other Xperias and I don't see this option
