Phone changes to Korean Keyboard
Nie dotyczy
Hi,
My phone spontaneously changed to the korean keyboard ( from English ). I have tried to get it back to English ( remove battery ) but no result. Who can help ?
Best Regards,
Arno
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
suze
Pasjonat
Also try on your sms text application, go to the text input box, long press then select input method and select standard or android.  This seems to happen quite regularly to people, quite often while the phone is in your trousers! Weird.
5 ODPOW. 5
Er_Kannan
Go to Settings> Locale and Text and change to your language. Hope this will help.
suze
Pasjonat
Nie dotyczy
Thanks to Suze my problem is fixed !!! Thanks a lot.
Arno
Nie dotyczy
Thanks Suze,
Also had same problem, tried adjusting through settings/locale & text and a few other things (even tried deleting Korean keyboard).
Anyone else had the same issue, got any idea why it happens?
Er_Kannan
Settings, thats it.
