Please help me ...Main BUG on Sony Walkman ICS
SOLVED
maxlele
Visitor
I'm using Sony Experia S and just upgraded to ICS , but i have this one problem where all the tract deleted is still appear in the Track Playlist and i'ts cannot be delete , even when after a long press and manually delete from the walkman track , nothing would happen . E.g Eminem-When Im gone , when i deleted the track its still appear in the playlist and eventually the track cannot be played. Would sony please do something about this stuff , it's really bothering me when i can't do anything about it , nor using the file manager or app manager .
1 ACCEPTED SOLUTION
Accepted Solutions
LarryA
Visitor
You need to trigger the media scanner to update it's index. Use an app like 'ScanMedia'.
If you delete the tracks through the Walkman app it automatically updates the index. If you deleted it through e.g. a file manager some of these apps don't update the index.
5 REPLIES 5
Arnab
Enthusiast
settings reset helps maybe, try to add or delete files using Media Go.
maxlele
Visitor
I've tried using all those thing but nothing worked .. is really troublesome , and if i open the file manager using the Pc companion , i saw all those songs that i deleted , but then i can't delete none of them . Is sony didn't take note of all these bug?
LarryA
Visitor
littleggyy
Visitor
Factory reset.
I had camera problems, storage problems after ICS update.
I factory reset it and it is working now. Although it is very laggy.
maxlele
Visitor
Thanks , all my problems solved now. I'm really glad to have u to help me .
