Plzzzzz..!!!!!! somebody HELP ME....~~~
GELÖST
Nicht anwendbar
    Today acsidently I removed my full data files with apps from my System. I did that with root explorar but after that I moved full data files from System to my SD Card... I'm really so stupid that's why i did this... then swich off my cell and try to on it again... But now it's just Re-starting again again... not working yet... And finally I realized that what mistake I done... but Thanks God.. I still have those data files on my SD card...
So does there have any Cordial person,, who can help me in this situation.... plz!!! anybody just let me know.. what I should do to  prevent this disgusting problem...!! plz get me some ideas.............
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
slimshaddy
Forenjunkie
well the software will tell you what all to do Slightly_smiling_Face
if still you face any problem we all are here Winking_Face
7 ANTWORTEN 7
uliwooly-wooly
Legende
use Update Service to repair your phone
Nicht anwendbar
Thank You so much Mr. Uliwooly.. Can You plz get me some idea how I would able to slove this problem practically.. I mean, what actually I would have to do with my cell phone... can you plz kindly tell me details.??? Slightly_smiling_Face
Nicht anwendbar
Thanks a lot for your Kind information,,,Now I'm downloading that update service setup...But I'm a little bit Confused, that what I would have to do after download this file..! Can You plz kindly get some idea how I would able to slove this problem practically by myself..??? I mean, what actually I would have to do with my cell phone... Plz Kindly tell me little details about repair my phone.. This is Sony Ericsson Xperia X10 mini pro...
Thank you once again for your kind help.... Slightly_smiling_Face :smileyplus:
slimshaddy
Forenjunkie
Nicht anwendbar
I'm writing here again to give you thnaks.. cause I already did it and able to repair my problem... Slightly_smiling_Face :smileygrin:
Thank You so much SlimShabby.......
Wish You all the best~~~~ :smileyplus::smileywink:
slimshaddy
Forenjunkie
hmm Winking_Face
