Power menu
Klaudijus1
Power menu
Sometimes I can't open power menu It just turns off display. Why? Now I'm on stock 4.3[201] I had same problems on custom roms based on stock[for example existenz 3.3].
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Klaudijus1
After the new update .205 the problem has disappeared Slightly_smiling_Face
10 ODPOW. 10
Danial-mach1
Pasjonat
maybe your power button is faulty
Klaudijus1
What do you mean? On stock 4.1 I didn't faced this problem.
Bee-Ant
If you're rooted, install Xposed Installer, and then install "Gesture Navigation" module on it. There's a swipe function to show Power menu... like, swiping from right edge to the left, etc etc. I've tried it once and it did work on 4.3.
Klaudijus1
I'm not rooted.
Klaudijus1
Can someone help me?
Bee-Ant
Try to fresh install 4.3, or just root it and then install Xposed installer as well as the module, or... just downgrade to 4.1.2.
I can't help much since I don't have this problem.
Klaudijus1
J0a0
Hi,
with BL locked and .205 firmware who can i root it!?
Klaudijus1
@J0a0 wrote:
Hi,
Flash stock 254 via flashtool[You won't lose be2...]. Then http://forum.xda-developers.com/showthread.php?t=2780836 Slightly_smiling_Face
