Problems connecting to the Internet...
Nie dotyczy
I have an X10 and have recently upgraded to android 2.3. Since then, I cannot connect to the internet through the mobile. Wifi is no problem. It lets me connect to data enabling but then says no internet connect when I try to load a page. Does anybody have any ideas?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
uliwooly-wooly
Legenda
can you access the market?
go to settings -> sony ericsson -> internet settings
who is your carrier?
3 ODPOW. 3
uliwooly-wooly
Legenda
Nie dotyczy
O2.
Many thanks. That was really helpful. It took a while to find the internet connection and download but it seems to be working now.
Thanks again.
uliwooly-wooly
Legenda
anytime
you can always do it manually
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
enter the info here
MENU -> save
don't forget to mark the correct and/or helpful answer(s)
