Hi everybody. I've bought my phone ten days ago and I've installed all the software update with Sony Update Service and/or PC Companion. When I make a phone call the screen goes black after 30 sec (in Display settings) and wont light up again until the call is finished. So if I had to tap any numbers I can't do it. I had to wait that phone call finish then push the button on the right side to go to home page. This is not a good functioning. Please help me!! Thank's in advance
The screen turning off completely has been seen in other xperia devices.Attempt a repair with sony update service or take the phone into service.
You should go for a software repair with the same programs.You know that while in a call,if the proximity sensor is covered,the screen is shut down,right?
I know, It should shut down when i move it near my ear (All smartphones have this function if i'm not wrong). Does this sony xperia doesn't have this option or there's a way to make it work?
Test your proximity sensor, there might be something covering, a protecting film, case or grime, etc
Dial *#*#7378423#*#*,service tests,proximity switch.See if when you cover it,you get yes.If you get yes all the time,there is something wrong with it.
I tried to do the test and it looks OK. The proximity test, at the start, was off, then, when I approach my finger to the phone it says ON. Now I make a test call to see if it actually works...
Ok,keep us updated.
It doesn't work, and now i can't do anything because the screen is completely black, even if i can still hear the voice of the secretariat saying if I want to send an oral text or retry to call etc. What is this problem due to?
Thanks so much for the help, hope to make everything works! I'll tell you if i'll be able to do something. Good night!
