I'm trying to repair my X10 Mini Pro but having problems when it comes to starting update after update software has been prepared on my computer in Sony Companion. When it comes to reconnecting USB to my phone, whilst holding Back button when phone is off, my PC freezes when installing SEMC Flash Drive, which results in me restarting PC.
I need help in fixing this problem.
Solved! Go to Solution.
Try updating in Safe Mode .... Reboot PC, keep tapping F8 till Safe Mode Menu appears. Select Safe Mode with Networking, contine with SE Update Srervice. Good luck! Hopefully it works this time, don't want my head to be chopped.
Hi, try SE Update Service. Here's the download link, http://dl-www.sonyericsson.com/cws/download/1/110/61/1317636927/Update_Service_Setup-2.11.10.7.exe.
Don't forget to backup your data.
What does it do?
It's a software repair and update tool.
Is it much better than the update service in Sony PC Companion?
All I can say is for SE Update Service is only for software repair and update (main function), while PC Companion has many other purposes.
You try it out and let me know if it is better ....
If it doesnt work and my PC freezes, I'll hunt you down and chop off your head.:smileysilly:
Btw, there is problem with connection to your servers.
Message was edited by: cat2k1
No problem, if you can find me. :smileymischief:
Actually .... you won't have time for that, you would probably pulling your hair and trying to find a solution!
Anyway, keep us updated.
Just waiting for Backup of phone to finish. It always takes long when backing up Text Messages.
Btw, anyone using Opera browser and experieincing problems with javascripts for this site? Its really annoying as I have to Use Advanced Editior to post messages on this site.
Just take your time, don't rush to it.
I have Opera Mini browser which is not possible to post on the Forum (at least you can :smileywink:), I use it for viewing the Forum only. I do my posting with stock browser.
