Random Wallpaper Problem
SOLVED
Luis_Gaudencio
Visitor
Hi everybody...
Sorry to bother you, but its really bugging me... I recently bought a Sony Xperia U, and I accidentally changed my wallpaper settings to random wallpaper... Problem is, that I can't find the place to change it back to the way it was... I've searched through all the settings options, including specific options of the camera and gallery, and nothing... Please help me if you can...
Thanks for the attention given...
1 ACCEPTED SOLUTION
Accepted Solutions
Luis_Gaudencio
Visitor
Ok, found the problem, sorry it was actually due to an app... I'm so sorry, and thanks Johan for the attention...
5 REPLIES 5
Johan
Master
You can change the wallpaper by pressing menu key > wallpaper.
Now choose the wallpaper you would like to use.
Luis_Gaudencio
Visitor
I already did that, and for I assumed it was done... But it keeps changing the wallpaper randomly from one folder... Even if I choose a wallpaper from a different folder it changes back to the previous one and maintain the random settings...
Luis_Gaudencio
Visitor
jechosantos
Visitor
Hi, may I know how did you find which app caused this problem? I have been experiencing this for a while and it is really bothering me. 😐
Luis_Gaudencio
Visitor
I was using Zedge app and didn't remember to uncheck the box that enabled the random wallpapers...
