Regarding Xperia P
SOLVED
Manish
Visitor
Regarding Xperia P
Hi All,
Please dont buy any xperia mobiles :smileyconfused:. It just sucks..:smileydevil: battery drains soon:smileycry:, problem with notifications and even problem with network:smileyalert:.
The battery status bar also have many bugs :smileyplain:. Once you restart your phone sometimes you will find a huge deviation on the status:smileyshocked:.
Does sony bothered to resolve these bugs Smiling_Face_with_Horns or they just want to launch new mobiles in market :smileylove:. !! Its just stepping towards the path of Nokia to get it shut down by launching mobiles with bugs.:smileylaugh::smileylaugh::smileylaugh:
i hope some of the sony moderator will respond or else again it will turn up as a discussion asusual and nobody will gain anything.!!
No more Hopes from SONY... :smileyangry::smileyangry::smileyangry:
1 ACCEPTED SOLUTION
Accepted Solutions
rusticguy
Visitor
I agree on the batter status.
It's all conky for sure.
Sony is all busy for 2013 phone called Sony Odin. So 2012 will be forgotten soon.
10 REPLIES 10
ryan515
Contributor
I agree with you in some part. but i think Sony is making a fix for it. They need some time to release a bug free update.
rusticguy
Visitor
coolprateek7
Visitor
I don't think battery is bad. It excellent actually. Take Iphone 5 's battery for instance it is 1440mAH battery and drains much quicker than this.  U can check it., but u pay more money and buy it.
Manish
Visitor
Hi Ryan,
Thanks for ur response but did any of the sony Moderator bothered to respond for this. Inspite of releasing new mobiles, it should concerntrate the critical bugs which are there in Xperia P or any other released phones and can take time to release new ones. Effort need to fix the bugs is more wen compared to developing new one.!!
Manish
Visitor
True dude... Sony is not concerned about the customers and trying to target all the segments now rather concenrtating on fixing the bugs...!!!!
Manish
Visitor
Coolprateek Iphone 5's functionalities and features are different from this so dont compare this with it. Compare it with the one which is of same range and have same features. Network drop issue was such a critical issue but still sony was releasing new mobiles and later on fixed this with ICS. So untill and unless we get JB it wont be resolved is it??
if some more bugs generate by fixing this will get resolved in "Key Lime Pie" update... LMAO.... :smileygrin: :smileygrin:
a_agarwal
Visitor
Key lime pie... JB.... Let them give the basic firmware updates to ICS first.
obirki
Visitor
Sony should concentrate about fixing these bugs instead of realeasing new models. I will not buy Sony again if they dosent solve these issues fast!
profile.country.RO.title
_alexdon_
Sony releases new models because they want to be in touch with the market,they don't bother fixing the bugs of older phones.
alexdon
