Hi,
I'm currently facing this problem and it's really annoying.
I never update my phone or whatever because it will slow it down.
My phone went out of battery and it turned off. So i plug the charger in and waited for it to restart. After restarting it, I realize there are several settings that ran away IE: My ringtone preferences and keyboard preferences. So far, I've already readjust it, But ever since the phone restarted like that, I can no longer lock my screen, not even if it times out itself after 15 seconds. and when i press and hold the power off button, instead of showing the menu for options like "Silent phone"/Flight mode"/"Shut down" it only shows power off. What can i do to get the original settings back ? HELP PLEASE !!!
repair it with SUS and do NOT install any app, if mcafee it's pre-installed remove it.
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
what do you mean update, update to Android 2.1 from 1.6? 2.1 it is a lot faster than 1.6 and fix bugs. you might have an antivirus, taskiller acting up
No, my phone IS already 2.1 and i'd like if you have the answer to my problem.
