i don't know if its because of ICS or something went wrong in my xperia s.
but in some games like Temple Run : Brave, Cut the Rope... or even when i open images... the screen start flickering.
does anyone have this issue?
and is it software related or hardware?
that seems to be a compatibility issue that must be fixed by the game developer
Don't forget to mark the Correct Answers & Helpful Answers
i thought so... but also as u checked its in the galary too (the first video).. and since its the same in another game but with less frequency i think its something with ics.. right?
I just watched the first video, it seems odd, repair your phone with SUS and check if the flickering with the photo app continues
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
ok... i will do in in few.
thanx
no problem, keep us posted
just finished now... and looks like the problem is solved
thank you
and i will tell u if the issue came back after.
Excellent
Good day!
I have most likely the same issue but in my case screen is flashing when in keypad lock mode ( I am using face unlock) when I lock my phone it will be blackout right? but after a few minutes it flashes in a randomed timing showing the face unlock screen even my phone is just sitting in the desk and no body touching it. What could be the problem Sony? Thank you hope you can help me.
did you tried all the suggestions above?
Sorry haven't tried it... should I bback up & restore first before using SUS? (sorry kinda innocent with this things)
