Hello All
I cant send any sms, when i decide to check my sms center number i was in for a shock.....the sms center is missing!!! how can i send sms now, is there any way...psl dont tell me i have to reinstall....oh god....pls help. Thanks in advance.
Opssss .... sorry, mixed up the * and #.
Glad that you figured it out :smileysilly:.
Not sure how is your sms setting being set up (depending on Network Operator).
Some are set up automatically when inserting SIM card in phone while some are set up by manual input.
Suggest you remove and insert your SIM card. If that didn't work, request it from your Network Operator.
Good luck.
Hi G whisperz ....Thanks for ur reply.... pls have a look at the the full details and do give a me reply : I updated the phone with the 2.1 S/w update and after a week today tried to send an sms and it was showing a message "could not send", so i was thinking my sms message center number was not correct. so i went to settings: wireless & network settings: mobile networks: ( This is where iam supposed to find the sms center for me to enter the number............ but itsssssssss missing
). How can i get it back. i dont want reinstall the s/w as last 1 week i have been saving all my old contacts, address, photos, important sms's , mail box all ....dont want to go trough that again..... pls help. Many Thanks.
Refer to my earlier suggestions, do the easy one first (actually both are easy :smileysilly:).
Remove and re-insert SIM card.
Thanks again Gwhizperz............. Tried both....Reinserted the sim ....but nothings happening and the network operator's dont have a clue about the sony ericsson xperia phone
.....im in India....3G has just been started and it will take atleast a year before the network people have some idea about android phones.... :smileysad:... i hate it...seems my relationship with sony phones will be that of love : hate
Try searching the web .... search for your Network Operator, maybe you might get lucky and stumbled onto the sms setting.
If you don't mind, provide me the name of your Network Operator, see whether I can come out with anything.
Its BSNL Cell one (India). I have the sms message center number (provided by the operator) but the space where i have to enter the number is missing. Thats why... im getting confused now ::smileyconfused: Thanks again gwhisperz
Lucky for you I have X10 mini with Android 1.6 and X10 mini pro with Android 2.1. After comparing, I understand what you meant!
For Android 2.1, goto your dialer, key in #*#*4636*#*#, a menu will appear. Tap Phone Information, scroll down to SMSC field, key in your message centre number in the blank field and tap Update.
This is one reason why I did not update my X10 mini to Android 2.1 (just in case I need to check some info)
Good luck.
Does this work on your X10 Gwhispererz? I had this before that I couldn't access this menu from either my X10 (UK branded T-Mobile) or my X8 world generic unbranded. Do you have to press the call handset icon or once you have put in the last # does the menu appear? Am I being a bit thick again!?!
Just played a hunch... its star hash star hash 4636 hash star hash star on my phones. Ooooohhhh a place I haven't explored yet! Me likes.
