SMS transfer from W995 to macbook
SOLVED
Not applicable
Hi,
I would like to back up my SMS folders to my macbook. I can only find information on how to do this on a PC but i only have a macbook and no access to a PC. Is there any way i can do this?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
5 REPLIES 5
Uliwooly
there's an amazing software for PC "My Phone Explorer" but the only way you could use it is if you install boot camp on your mac and windows 7.
now the other alternative will be blue phone elite
http://mirasoftware.com/BPE2/
Not applicable
Hi,
Thanks for the fast reply but Blue phone elite is no longer available and i don't want to buy windows just to transfer SMS.
Uliwooly
Not applicable
Many thanks,
That works great.
Uliwooly
anytime
