Sony Xperia Pro ?
profile.country.IE.title
rknerd93
Sony Xperia Pro ?
Will the Sony Xperia Pro release in Ireland?
7 ODPOW. 7
profile.country.IT.title
Marino.Manolo
Genius
Only in Japan I think, for now at least...
rknerd93
It is on the USA site also.
Gilgameshuk
No sadly we won't get it
The "Americans" will get it but no joy for us i'm afraid 😞
Gilgamesh the first ONE and ONLY King
profile.country.US.title
Qatrium
@rknerd93
A call to your local support center might give you the answer if they were provided with this info.
Gilgameshuk
The reason is the Americans use a differing 5G wavelength from us in Ireland and the UK
The Pro is designed for the wavelengths of 5g that the Americans use, so sadly there is no chance of it
ever coming over here.
rknerd93
Will Sony xperia 1 Mark II work on Vodafone Ireland 5G network?
Gilgameshuk
Yes it will
Ireland will be utilising the same type of 5G as the UK does.
Xperia 1 mki ii that is
The Pro version (if you cAN get it) i don't think it will as its built for 5g bands within the USA.
