Sony Xperia SP Touchscreen intermitent problem
ginfaleanbogdan
Hello, i have a little problem on my xperia sp device, sometimes it lets me slide down the notification panel, sometimes it doesnt. I have reseted the phone and even an software update and didn't helped me.
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Thommo
Genius
Do you have a screen protector placed on your phone? You could also run a test via the Xperia diagnostics app to see if you have a digitizer issue
8 ODPOW. 8
Thommo
Genius
Samuel1
Zawodowiec
If Thommo's tip doesn't help, you should send in the phone to a service center for repair. Contact your local Xperia Support for more information.
ginfaleanbogdan
I did that, and by the time it got there it worked properly and they said nothing could be done and its working fine
Uliwooly
@ginfaleanbogdan
Repair the phone with PCC and see if you experience the same issue again
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
ginfaleanbogdan
i did that and it doesnt work Slightly_frowning_Face
Uliwooly
Contact your local Xperia Care
ginfaleanbogdan
Im going to make a video with the problem and send it back to service
Thank you all for the advices
Uliwooly
Anytime
