The best android apps for xperia x8
SOLVED
Not applicable
Guys,Plz suggest some of the most useful and entertaining android apps for xperia x8,,
40 REPLIES 40
Not applicable
You must try guitar hero 5 application, it rocks :smileygrin:
Not applicable
can any one tell me best application for Camera...i think camera is the bigest drawback...
Not applicable
Camera Advance is a good choice. I use the free version, Camera Advance Lite, and it doesn't dissapoint me. Slightly_smiling_Face
Not applicable
  1. Monkey Business Free (live wall paper) Slightly_smiling_Face
  2. ESPNcricinfo
Not applicable
I am looking for any app with which I can have maps saved in my phone for offline use. Is there any such app available in market.
Not applicable
Hi,
Could u tell me how we can install & use Barcode Scanner. How much time X8 takes to scan & give details of a product.
suze
Leader
If your X8 has the 2.1 update then you may have an app called NeoReader which is a barcode scanner, however there are various apps on the Android Market that you can download as well.
Not applicable
how to disable the default message? to use only the handcet app
suze
Leader
When in your original text messaging app, press the Menu button (bottom left) and then select Settings and untick notifications.
Not applicable
the best app to use for lined barcodes (the ones you see on all everyday shopping products) is red leaser its free n ive never had a prob wiv it.:smileygrin:
